Client has a home router but also wants to serve a workshop just outside her router’s range. I was thinking of just replacing the router with an RB751 and hooking up a directional antenna to the external MMCX jack.
I’m asking to see what particular model antenna people like and have used in the past for this purpose – a modest SOHO directional antenna, hopefully with a compatible connector.
If you are stuck on using the directional antenna I would just use an SXTG-2HnD. But you might be better off setting up a pair of 751Gs and making one a repeater and setting it in her shop. Without seeing everything or knowing more about the layout it is hard to tell.
The WiBOX looks very nice, but is a router enclosure, plus it doesn’t seem to be available in the US. I was looking for something more on the order of a dumb directional antenna capable of plugging into the provided MMCX jack in the RB751. In other words, this level of product:
As it turns out, after viewing this client’s physical layout, the distance and layout requirement is more demanding than I expected, so I’m going to go with StationTik box at the remote site containing an RB411 PTP unit plus an additional radio card to run a small local omni. Thanks for your help.
