Suggested CAPsMAN Hardware
We want to install a wireless infrastructure over a building with about 10 CAPs und up to 200 Wifi Clients.
We want to have local forwarding disabled, the obvious firewall rules on the CAPsMAn and a Quality of Service (PCQ for about 80Mbit/sec for all Clients) with the Mangle rules we need for this. The CAPsMAN will also be a DHCP Server.
Is there a suggestion for a Hardware Router that can handle this traffic and the QOS?
Greetings, and sorry for bad english.
Can anyone help please?
I coulnd’t find any information on the web.
Thanks.
RB1100AHx4
Thanks for your reply.
The RB1100AHx4 seems a little to mouch to me. Maybe I forgot to mention, that the Wifi installation in only for Internet Access for the clients. And to share the 80 mbit internet connection equally with a pcq queue.
Greetings
What about freshly announced
RB450Gx4 with 4-core CPU, 1 GB of RAM and hardware IPsec encryption
Thanks for your suggestion.
The new RB450Gx4 isn’t available (yet) in our stores.
What about the RB2011iL-IN? Do you think this is enough for our purpose? Or can we use the old RB450G? We dont need IPSec.
Greetings
2011 won’t be nearly enough for this, at least not with QOS. You might get away with the 2011 if you can live without QOS; because you can fast-track most of the internet traffic.
I second RB1100x4 as previously suggested , or you could maybe use RB3011.
What’s wrong with RB750Gr3, I use it with 7 Wap Ac, we have 150mbit line, and few queue tree rules, one simple queue for guest network, and up to 70 clients, works fine.
Note I use local forwarding, not sure if it would work so good with capsman forwarding, u may need use higher cpu power product than.
Ok,
Thanks for the replies.
Local Forwarding isn’t an option, so we need some model with higher CPU. Also Fast-Track can’t be used, because we need some firewall rules to hide the rest of our network from the CAPs Clients.
I think we will go with RB1100x4 or maybe we will try the RB3011.
I will report later when everything is online. :slight_smile:
Greetings
I had only but issues with capsman forwarding, perfomance was very bad without CPU going even over 50%, and i had all this network traffic like printers, and network shares going thru router, hitting queues etc, at the end i used local forwarding and only capsman forwarding for guest network.
Looking forward hearing how did your setup go.
think also about future upgrade of your internet line or expanding your installation with more caps.
i vote also for RB1100x4. the machine is a litle beast.
I will suggest you https://mikrotik.com/product/RB750Gr3
RB750Gr3
