Suggestion: Ability to Create New Tables (like iptables) or at least group rules
The problem:
Filter table gets so polluted that on routers with lots of rules, it’s difficult to understand what’s being filtered and why sometimes. If you have dynamic rules, it makes it even more challenging.
On iptables, there’s a solution for this by creating additional chains, and then joining those chains to the input chain.
If RouterOS is already capable of this, how do we achieve it?
I’m at 90 rules on my one router and as much as I’d love to add more rules to it, I’m reluctant to simply for the reason that it will become more unusable and the chances of me having forgotten about some edge cases to account for because of the mess is quite high. If I could organize it, it would make it so much more manageable.
The particular use case where I have requirement for a lot of filter rules:
I have a master VPN server. That VPN server is used by my own company and a number of clients. I want my clients to be able to access all of their assets, but nothing else. I want myself and my techs to be able to access all of our assets, and all client assets. I have monitoring servers that also need to be able to access all client assets.
Sometimes I will need to put in additional masquerade rules so that the end customer doesn’t see subnets from outside their known world showing up in their logs as well.
jump
You can create own chains and jump to…
/ip firewall filter add chain=custom ...
/ip firewall filter add action=jump jump-target=custom ...
no need two instructions,
simply first jump instruction on new chain create the new chain
Sure, but you want the chain to contain rules, no? :slight_smile:
ok, misunderstanded:
I usually do:
add action=jump chain=input comment="Inizio Protezione IP Pubblico 1" dst-address=0.6.6.6 in-interface=ether1 jump-target=input_gateway
add action=jump chain=input comment="Inizio Protezione IP Pubblico 2" dst-address=1.9.9.9 in-interface=ether2 jump-target=input_gateway
add action=accept chain=input_gateway ...
add action=drop chain=input_gateway ...
add action=return chain=input_gateway comment="Fine Protezione IP Pubblico"
Thank you guys.
I keep forgetting it's almost exactly the same as iptables.
Remember it is named “jump” but it is actually “call” (for those who know about programming).
So, indeed you can “return” to the place where the “jump” was done, and in fact this is what happens automatically when the jumped table just ends without a terminating action (drop, reject, accept).
This may be unexpected to new users. I normally make sure that any table that I “jump” to ends in a “add action=drop” just as I use at the end of the input and forward tables (I like to do a default-drop configuration where everything I want to allow as an “accept” and at the end of everything there is a “drop” or “reject” instead of the default “accept” that is in RouterOS).
