Hello there,
I was glad to hear thaht /ip/route/check was added in 7.18,
But it seems VRF / routing-table support was not added to the tool since,
I tried to check the nexthop with src-ip an IP existing only in some VRF, and dst-ip an IP existing in the routing-table associated with my VRF, and the result is always the same : the nexthop is the one from main routing-table,
This tool is useful, but not if you use VRF / different routing-tables,
What about adding this functionnality ?
Thanks,
