I’ve been dealing with MT connected to three ISP links, and I needed one simple feature evailable even under Windows - option to set materic for the interface.
Thing is MT sets distance for dynamic default routes on it’s own (or at least I could not find a way to make a change). If I want default route to have changed metrics I have to set static default route. Problem is that I have an dynamic IP and when IP changes even gateway changes, so my static default routes became obsolette.
Windows has simple option, one can set importance order of intefaces, and metric for default routes on that interfaces would be set according to that settings.
In Routing add a route using the Interface as the Gateway instead of a IP address. This way you can specify a cost..
Example
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 3g1 10 3g1
1 A S 0.0.0.0/0 r zen 5 zen
2 A S 10.0.0.0/8 r 10.65.81.254 1 redbus
3 ADC 10.65.81.254/32 10.65.81.235 0 redbus
4 ADC 10.81.235.0/24 10.81.235.254 0 Secure
5 ADC 10.112.112.132/32 10.227.211.34 0 3g1
6 ADC 62.3.86.7/32 82.69.103.144 0 zen
7 ADC 192.168.1.0/24 192.168.1.10 0 dsl1
