I need a router/switch/access point. Everything will be placed inside a cabinet, so I need to put the antenns in a remote (2 meters) location. I think to have 2 options:
buy a RB2011UiAS-2HnD-IN, remove the antennas, and put a 2 meters cable from the router to the antennas. Do you thin that can be a good solution? Which type of cable I need to buy to move the antennas?
Buy a RB2011iL-IN and and an access point, with a network cable I can connect the access point to the router.
I think that the second solution is the best but I do not find an access point with a gigabit interface.
What do you think about it?
Thanks in advance
m
HI, I just need to use it inside my home with a 802.11n connection , so I do not need any special antenna, I think that the built in antennas ar good for my purpose, I just need to move them 3 meters away from the device.
Thanks. Last question is:
I wish to put the 2 antennas inside a box, to hide them from the view…do you have any suggestion about which kind of box to use?
Thanks and regards
m
