Suggestion needed for building wireless backbone at home
Hi guys, I need your help to suggest what is the best way to achieve high performance with below diagram, I need to transport a few VLAN from RB1100AHx2 to all the switch wirelessly. I understand the PTMP link is doable for it but it’s slower as routing needs to be done at router side. Appreciate if you guys could assist on this.
To be short : Transport multiple VLAN wirelessly to multiple CRS109-8G-1S-2HnD-IN & perform routing in CRS109-8G-1S-2HnD-IN.
Thank you.
Wires are the best. Otherwise use wds and make the link between all devices that you want to pass majority of load in between. Then use routing instead bridging to speed up the transfers in the right way directly. Sharing one frequency and omnidirectional antennas will not help you to get perfect results.
I agree with Jarda. Use wired connections to your APs otherwise you’re halfing your bandwidth for clients. And use routing instead of bridging. In this way, you’ll limit your broadcast traffic.
