Suggestion: Primary Address for each interface
In IP → Addresses, you may or may not have multiple Addresses on a single interface. The first ip address is always the one that shows up in traceroute etc… I would like to suggest instead of removing the first one and re-adding it could you make a toggle button of some sort to mark which ip address you would like listed first. It’s not a very hard suggestion and It wouldn’t really conflict with anything.. Anyone have anything to add to this? I am sure a lot of us would benefit from having this.
My suggestion is to make a check box of which IP for each interface is the Default(1st) IP on the interface. By default the first ip would be the “Default” IP, but when you add another IP you have the option to make it the “Default” IP.
ADDRESS RT1 RT2 RT3 STATUS
1 68.187.21.109 2ms 1ms 2ms
2 172.17.0.1 2ms 1ms 2ms <----- see this the ip on the output interface of this router the local ip is listed first.
3 68.119.96.33 20ms 10ms 17ms
4 96.34.71.178 4ms 5ms 4ms
5 96.34.79.72 16ms 14ms 14ms
6 96.34.79.116 14ms 14ms 14ms
7 96.34.79.137 26ms 26ms 27ms
8 96.34.2.70 27ms 35ms 36ms
9 96.34.3.17 28ms 28ms 27ms
10 96.34.150.50 27ms 28ms 27ms
11 64.233.174.2 28ms 28ms 27ms
12 66.249.94.6 28ms 28ms 28ms MPLS:L=10805,E=4
13 209.85.248.29 28ms 29ms 28ms
14 8.8.8.8
Support anyone?
I wasn’t sure which forum to post this in, so moderator move it to where ever you best see it fit.
What is the benefit of this? You can always src-nat the outgoing traffic to whatever you want, anyway.
Yea but would it not be just easier to click or set a Ip address as the primary address…
You can change pref-src address in “connected-in” routing filter chain
Anyone point me to where the last post is talking about?
You can use pref-src on 0.0.0.0/0 route rule.
