Suggestion: simple speed limiter
current Queues has a very large number of settings and a very complex and confusing.
Please add simple speed limiter.
Simple queue is perfectly adequate for this. Just use the first tab. What is it you are trying to limit?
With only first tab is impossible to perform an elementary task in one queue:
set summary limit + set per IP limit
Have you looked into Queue type PCQ? I thought that would do what you are looking at?
we are talking about only first tab
Yep. Those 2 drop downs in the advanced tab are too far out of reach :sunglasses: :laughing:
Advanced tab also not enough in this case.
Have you tried TP-Link or D-Link?
I am sure they are much easier with all their wizards whistles and bells.
If you find RouterOS hard, then it’s probably not for you.
So you want simple, but not too simple… :smiley: Thats gonna be hard to satisfy
