[Suggestion] Winbox color Changeable as a color mark
High all,
I suggest to make winbox background color or any color mark changeable , to give ability to differentiate, if I was using more than MikroTik server at the same time .
You know it is a heavy when you do that , you don’t need to make mistake . :wink:
all that beside the title bar , it is good as it is now ,
admin@server great when it is minimized .
