Suggestions on Configuraiton of CRS326-24S+2Q+
I have recently configured this switch as a ‘core’ style switch for the network. All the switches connect here and then goto the router or server. The router controls the vlans at the moment. Anyone have any suggestions on how to improve on this or where to go learn more to improve on this.
Thank you
# oct/22/2021 10:34:11 by RouterOS 6.49
# software id = 9DYC-9G3A
# model = CRS326-24S+2Q+
# serial number = D84F0C8135CC
add frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes \
    name=Trunking vlan-filtering=yes
set [ find default-name=sfp-sfpplus11 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full \
    l2mtu=1592 name=HUMC_NVR speed=10Gbps
set [ find default-name=sfp-sfpplus17 ] advertise=\
    auto-negotiation=no l2mtu=1592 name=humc_srv_p1 speed=10Gbps
set [ find default-name=sfp-sfpplus18 ] advertise=\
    auto-negotiation=no l2mtu=1592 name=humc_srv_p2 speed=10Gbps
set [ find default-name=qsfpplus1-3 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=qsfpplus1-4 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=qsfpplus2-1 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=qsfpplus2-2 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=qsfpplus2-3 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=qsfpplus2-4 ] disabled=yes l2mtu=1592 speed=25Gbps
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no l2mtu=1592 name=\
    router_p1
set [ find default-name=sfp-sfpplus2 ] l2mtu=1592 name=router_p2
set [ find default-name=sfp-sfpplus16 ] l2mtu=1592 name=sfp16
set [ find default-name=sfp-sfpplus10 ] l2mtu=1592 name=tr_aw_sw01_p1
set [ find default-name=sfp-sfpplus9 ] l2mtu=1592 name=tr_aw_sw01_p2
set [ find default-name=sfp-sfpplus5 ] auto-negotiation=no l2mtu=1592 name=\
    tr_aw_sw02_p1
set [ find default-name=sfp-sfpplus6 ] auto-negotiation=no l2mtu=1592 name=\
    tr_aw_sw02_p2
set [ find default-name=sfp-sfpplus8 ] auto-negotiation=no l2mtu=1592 name=\
    tr_aw_sw03_p1 speed=10Gbps
set [ find default-name=sfp-sfpplus7 ] auto-negotiation=no l2mtu=1592 name=\
    tr_aw_sw03_p2 speed=10Gbps
set [ find default-name=qsfpplus1-1 ] advertise=\
    auto-negotiation=no l2mtu=1592 name=tr_aw_sw04_p1 speed=10Gbps
set [ find default-name=qsfpplus1-2 ] auto-negotiation=no l2mtu=1592 name=\
    tr_aw_sw04_p2 speed=10Gbps
set [ find default-name=sfp-sfpplus12 ] advertise=\
    l2mtu=1592 name=tr_cw_sw01_p1
set [ find default-name=sfp-sfpplus13 ] advertise=\
    l2mtu=1592 name=tr_cw_sw01_p2 speed=10Gbps
set [ find default-name=sfp-sfpplus14 ] l2mtu=1592 name=tr_cw_sw02_p1
set [ find default-name=sfp-sfpplus15 ] l2mtu=1592 name=tr_cw_sw02_p2
set [ find default-name=sfp-sfpplus19 ] l2mtu=1592 name=tr_cw_sw03_p1
set [ find default-name=sfp-sfpplus20 ] l2mtu=1592 name=tr_cw_sw03_p2
set [ find default-name=sfp-sfpplus21 ] l2mtu=1592 name=tr_tnr_sw01_p1
set [ find default-name=sfp-sfpplus22 ] l2mtu=1592 name=tr_tnr_sw01_p2
set [ find default-name=sfp-sfpplus23 ] l2mtu=1592 name=tr_tnr_sw02_p1
set [ find default-name=sfp-sfpplus24 ] l2mtu=1592 name=tr_tnr_sw02_p2
set [ find default-name=sfp-sfpplus3 ] l2mtu=1592 name=tr_tnr_sw03_p1
set [ find default-name=sfp-sfpplus4 ] l2mtu=1592 name=tr_tnr_sw03_p2
/interface bonding
add mode=802.3ad name=humc_srv slaves=humc_srv_p1,humc_srv_p2
add mode=802.3ad name=router slaves=router_p1,router_p2
add link-monitoring=none mode=802.3ad name=tr_aw_sw01 slaves=\
    tr_aw_sw01_p1,tr_aw_sw01_p2
add link-monitoring=none mode=802.3ad name=tr_aw_sw02 slaves=\
    tr_aw_sw02_p1,tr_aw_sw02_p2
add link-monitoring=none mode=802.3ad name=tr_aw_sw03 slaves=\
    tr_aw_sw03_p1,tr_aw_sw03_p2
add link-monitoring=none mode=802.3ad name=tr_aw_sw04 slaves=\
    tr_aw_sw04_p1,tr_aw_sw04_p2
add link-monitoring=none mode=802.3ad name=tr_cw_sw01 slaves=\
    tr_cw_sw01_p1,tr_cw_sw01_p2
add link-monitoring=none mode=802.3ad name=tr_cw_sw02 slaves=\
    tr_cw_sw02_p1,tr_cw_sw02_p2
add link-monitoring=none mode=802.3ad name=tr_cw_sw03 slaves=\
    tr_cw_sw03_p1,tr_cw_sw03_p2
add link-monitoring=none mode=802.3ad name=tr_tnr_sw01 slaves=\
    tr_tnr_sw01_p1,tr_tnr_sw01_p2
add link-monitoring=none mode=802.3ad name=tr_tnr_sw02 slaves=\
    tr_tnr_sw02_p1,tr_tnr_sw02_p2
add link-monitoring=none mode=802.3ad name=tr_tnr_sw03 slaves=\
    tr_tnr_sw03_p1,tr_tnr_sw03_p2
/snmp community
add addresses=::/0 name=HUMC
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=Trunking interface=tr_aw_sw02
add bridge=Trunking interface=humc_srv
add bridge=Trunking interface=router
add bridge=Trunking interface=tr_aw_sw03
add bridge=Trunking interface=tr_aw_sw01
add bridge=Trunking interface=tr_cw_sw01
add bridge=Trunking interface=tr_cw_sw02
add bridge=Trunking interface=tr_cw_sw03
add bridge=Trunking interface=tr_tnr_sw01
add bridge=Trunking interface=tr_tnr_sw02
add bridge=Trunking interface=tr_tnr_sw03
add bridge=Trunking interface=HUMC_NVR
add bridge=Trunking interface=tr_aw_sw04
set discover-interface-list=all lldp-med-net-policy-vlan=1
/interface bridge vlan
add bridge=Trunking tagged="humc_srv,router,tr_aw_sw02,tr_aw_sw03,tr_aw_sw01,t\
    r_cw_sw01,tr_cw_sw02,tr_cw_sw03,tr_tnr_sw01,tr_tnr_sw02,tr_tnr_sw03,tr_aw_\
    sw04" vlan-ids=10
    sw04" vlan-ids=20
    sw04" vlan-ids=30
    sw04" vlan-ids=40
add bridge=Trunking vlan-ids=1
add address=xx.xx.xx.2/24 interface=Trunking network=xx.xx.xx.0
set servers=xx.xx.xx.10
add distance=1 gateway=xx.xx.xx.1
/snmp
set enabled=yes trap-community=HUMC trap-generators=\
    temp-exception,interfaces,start-trap trap-version=2
/system clock
set time-zone-name=America/Chicago
/system identity
set name=CoreSwitch
/system routerboard settings
set boot-os=router-os
/system swos
set address-acquisition-mode=static allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,\
    p9,p10,p11,p12,p13,p14,p15,p16,p17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27\
    ,p28,p29,p30,p31,p32" identity=MikroTik static-ip-address=10.10.50.2
