I’ve bought this CF for my MT installation but I’m heading problems with booting, after I’ve made netinstallation succesfull ROS don’t want to start and sys said there’s no OS, is there anything I havo to do - because I’ve made it normal like connected CF, installed ROS with formatting.
What kind of device is this? A PC? How did you connect the CF, with a CF-IDE adapter or a USB adapter? The USB might not work.
I’m using PC with CF-IDE adapter (tested two diffrent) and ROS 2.9.38
maybe PC is at fault? Check various BIOS setting combinations. Have you tried another PC? also try reinstalling with netinstall, maybe something went wrong.
As a matter of fact I’ve been trying bios setting byt I will try with another PC
ok, sundisk works great with mt - that was mainboard problem, I’ve tried another and it works
