I can’t get a basic dstnat to work at all. Ports show up as open, but traffic doesn’t seem to get forwarded to the server behind the router. Port forwarding with my last router in the same exact configuration worked perfectly. Any help greatly appreciated.
[admin@MikroTik] /ip firewall nat> print
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=ether1-gateway
1 chain=dstnat action=dst-nat to-addresses=192.168.88.100 protocol=tcp
dst-address=*.*.*.* dst-port=25565
2 chain=dstnat action=dst-nat to-addresses=192.168.88.100 protocol=tcp
dst-address=*.*.*.* dst-port=8080
Just to make sure, was your last router a MikroTik?
I’ve not tried matching all IPs with the syntax you are showing, Did you '’ out the real public IP? Or does your config really contain the ' 's?
If so, you might try this instead, untested:
add chain=dstnat action=dst-nat to-addresses=192.168.88.100 protocol=tcp in-interface=ether1-gateway dst-port=25565
add chain=dstnat action=dst-nat to-addresses=192.168.88.100 protocol=tcp in-interface=ether1-gateway dst-port=8080
Now these ports seem to just be timing out.
Is it possible that your server doesn’t accept non-local connection requests (e.g. a windows machine with default firewall settings)?
In this case an additional
chain=srcnat action=masquerade out-interface=ether2-master-local
(put your internal interface there…) would do the trick.
I upgraded to v6.0rc12 because I’ve been having so many problems with this router.
My previous router was a random linksys. I had no problem forwarding these ports with it. The servers I have running are definitely configured to receive any incoming connections, as again, they were working fine before I got this MikroTik router.
This is what my firewall rules look like currently:
chain=srcnat action=masquerade to-addresses=0.0.0.0
dst-address=**.**.**.** dst-port=8080
3 chain=srcnat action=masquerade out-interface=ether2-master-local
I’ve tried a whole bunch of different configurations which should all work, but nothing ever seems to. Is there anything I could be missing?
cbrown
April 1, 2013, 3:45am
6
Post your whole config just incase something else is messed up.
/export compact
Most of this stuff is just default. I added a couple static addresses, a public dns server, and the firewall rules. Please let me know if there’s anything here I can improve.
[admin@MikroTik] > /export compact
# jan/02/1970 16:39:19 by RouterOS 6.0rc12
# software id = 2V3C-5786
add admin-mac=D4:CA:6D:6A:CF:A3 auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=\
indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge ssid=\
"MikroTik"
set 2 master-port=ether2-master-local
set 3 master-port=ether2-master-local
set 4 master-port=ether2-master-local
/ip neighbor discovery
set wlan1 discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys \
wpa-pre-shared-key=*** wpa2-pre-shared-key=***
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1 \
network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no \
/ip dhcp-server lease
add address=192.168.88.100 mac-address=00:13:D4:B9:A3:29
add address=192.168.88.200 mac-address=58:B0:35:61:EE:9D
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=4.2.2.2
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=\
ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=25565 in-interface=ether1-gateway \
protocol=tcp to-addresses=192.168.88.100
add action=dst-nat chain=dstnat dst-address=**.**.**.** dst-port=8080 protocol=\
add action=masquerade chain=srcnat out-interface=ether2-master-local
/system leds
set 0 interface=wlan1
/tool mac-server mac-winbox
cbrown
April 2, 2013, 11:36am
8
Disabled the last rule (drop rule) in /ip firewall filter and see if that works.
It would be easier to use the Netmap action to perform port forwarding.
add action=netmap chain=dstnat comment="Your Comment" disabled=no dst-port=8888 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.1.50
This statically maps the external port “8888” on ether-1 to the specified machine 192.168.1.50.
