Super newbie question on destination nat
Here is my setup:
public ip’s–mt2.9.5—5.8Ghz ptp link—mt2.9.5
On the public IP side I connect to the mt box directly with it’s default live ip x.x.x.y. I would like to connect to the other mt box using another live ip that is dst-natted. All private address routing works correctly
So I add the ip x.x.x.z to the mt box on the public side, and I add a dst-nat rule:
ip firewall nat add chain=dst-nat dst-address={x.x.x.z} action=dst-nat to-addresses={a.a.a.b} to-ports=0-65535
however when I connect to x.x.x.z I still get the box on the live side. Is there another rule I should be adding in?
David
You forget to add protocol and port number. Anyway, I think you should not use the same service port number on both servers.
/ ip firewall nat
add chain=dstnat dst-address=x.x.x.z protocol=tcp dst-port=80 \
    action=dst-nat to-addresses=a.a.a.b to-ports=0-65535 comment="" \
    disabled=no
I added it as per your example above but still no joy. It still gets me to the source router.
