Super simple Q!, setting up 2x APs
Hi guys,
So I just bought 2x cAP ac along with 1xhEX PoE.
The APs are connected by wire to the router and powered over PoE.
And the router is connected to WAN internet.
I want to setup my APs so that they give me ONE wireless network (ie ONE ssid) that covers both 2GHZ and 5GHZ band, as I have some devices that does not support 5Ghz.
(The default setting is giving me 4x wireless netoworks (2x 2ghz + 2x 5ghz) with different ssid)
How can I make this possible?
I have googled alot and not been able to find my question.
Many thanks for quick replies.
Seeing everything as a single connection is impossible, if the smartphone has dual band working perfectly.
You can not use the same MAC for different interfaces on same LAN or WLAN.
You everytime obtain 4 different network (Identical SSID or not)
At most you can use CAPsMAN on hEX PoE.
Many thanks for your reply
My goal is not to use ONE mac for all 4, rather ONE ssid (network name), so that devices can connect seamless.
Why can I just use ONE ssid on all the 4 networks, but them being separated by bands and channels?
You can use the same SSID for all 4 without the minimal problem…
EXCEPT: must have same security configuration (same wpa2-psk only, aes-ccm only and wpa2 password)!!!
Many thanks for your kind answer.
One issue now only. If I set the AP “Home Ap Dual”- mode in QuickSet, I get the SSID config as I want it.
But I cant access the internet.
But if I set the mode to “Wisp AP” and active the “bridge” option, I get the internet to work. But I lose the 2.4ghz band network option, and only the 5ghz band is presented.
How can I make the internet work and still have 2 bands
Sorry for newbie questions
Not a quickset option (I think ?) but CAPSMAN on Hex seems to be the best choice for your requirements.
1 SSID, 2 bands on each AP, 1 central point for management/security/…
Here is good starting point: https://wiki.mikrotik.com/wiki/Manual:Simple_CAPsMAN_setup
