Superchannel AP BRIDGE + NanoStation2 Client
Hi
I have a rb333 + superchannel licence, use a Wireless Interface in 2.377Mhz AP Bridge mode
In my cliente, have a NanoStation2 new firmware open a 2.3 frequency Client Mode
and not works
any have idea 4 this???
tks
If you don’t see AP on MikroTik device. It’s clearly problem of the client device and you have to look where is the problem with used client device.
did you try on another frequency? on RB333?
because the NS2 you have to put on compliance test.. and is 2.3 - 2.6 ghz
… also check, if the NS2 has frequency shifting enabled.
in 2377Mhz the signal will be lower than 2457 (exemple). Make sure you have enough signal.
