Superchannel free from v4.3
It looks like superchannel is available free of charge since v4.3, or maybe I’m getting old and have forgotten that I purchased superchannel licenses for all my routers.
yes, it is.
That is great news. :smiley:
Thanks Mikrotik.
Don’t need to buy more superchannel license. :smiley:
Too bad 4.3 hasn’t nstreme stable :confused:
where or what is this supperchannels?
It’s called “Compliance Testing Mode” and allows you to use any frequency that your wireless card supports. This usually means 5Mhz steps from ~4.9 to ~6GHz and from ~2.3Ghz to ~2.6Ghz
This mode should be used either in controlled environments, for testing, or if you have some special permission from the government to use non-standard frequencies.
All my 2.4 GHz card I tested so far goes from 2.192 - 2.539 GHz.
ok, probably you are right
No, I wasn’t correct. I found one card that goes from 2.312 - 2.732. :confused:
It’s the same chipset, but another maker.
Thanks for the great news.
Normis;
Could you guys do this for v3.x aswell ? I need them for my CPEs so badly.
Normis…
Is the truth the Nstreme is not stable in V4.3?
How about V4.3 with R5h, the wds configuration remain the same?
Excellent
/me goes to upgrade
