Superchannel license
Hello
This might be a dumb question, but here it goes…
How, where can I get superchannel license for my MT equipment?
support@mikrotik.com
You will need some support document then only they will release you the super channel…
everybody can order superchannel, just talk to your distributor.
only extending the channel-ranges needs a document, just using it doesn’t require anything.
