superchannel scanning
Hi
I have an RB532 with 2.9.xx mikrotik on cm9 and prism cards
I have bought the extra channels pack but i have the problem
that when i scan it scans ONLY the frequencies defined in the
country zone NOT all the supported frequencies
YES I DO have selected superchannel at the setup
Any solution?
add frequencies you need in scan list. By default there are not superchanels
OK
it works. Thank you
