Superchannel
I followed the procedure about superchannel and it was enabled.
I can’t seem to find a way on the online shop to buy the superchannel add-on on its own.
There is only a check-box when buying a new license.
When you say that keys cannot be upgraded i know it means i can’t go from lvl 4 to lvl 5 by paying the difference, but does it also mean i can’t use superchannel without obtaining a new license?
I sent to support@mikrotik.com and they said to me this
please fax us a letter where you say that you will use the additional frequencies according to your local laws, example here:
http://www.mikrotik.com/pdf/extend.pdf
make the letter on a company letterhead and it should be signed and stamped by an authorised company representative
we will then enable this feature on your mikrotik.com account. fax number:
+371 6 7317701
Each upgrade will cost 10$
Regards,
Normunds
Yes I have already sent the fax and my account has it enabled. There is a checkbox under the license that says “Custom Frequencies” which cost 10$ and i assume that’s the one. However, as i said its only on a new license. I want to “install” the add-on on my level 5 license.
I wonder why cost me 20$…
Hi
Want to upgread Custom Frequency with Existing License
Click “Work with Key”
Select the Key in a root folder & Click on Upgread. You will get an option of custom frequency. Just Pay 10$ and Paste the new Key in your Router.
Thanks, just made the upgrade succesfully :].
I dont know how to use superchannel.
I’ve set on one side Superchannel with no_country_set but when I do a scan it doesnt show my AP. At the client side is identical. What am I missing?
Can I use SuperG in any channel?
I used 2492 channel, not far from standard channels.
both sides have to use wireless mode “superchannel”, and for the client to see the AP you have to enter the APs new frequency range in client’s “scan list” parameter in wireless settings.
The client side see the AP in superG but can’t connect. If I set 2437 it works…in any other channels wont work. What can I do?
I try to update a RB532, and when I click in upgrade, it tells me “This key already have full features!”, and i got no superchannel support in that board!!!, somebody help me please.!!! It works on 2.9.50 ROS ??? It´s a 532… non 400 mhz, 32 MB RAM… work with ROS 3.x ???
Then copy the license from your control panel and install it in the Routerboard. (Import key)
Look under System License and see if the extra channels shows up under the “Features” window.
Tom
I read some posts, and seems I need to update to ROS 3.xx to install superchannel license feature in my RB… The question is: ROS 3.xx works good on this 532…?, I repeat is not a 400 mhz cpu one…
you don’t have to upgrade to v3 if you don’t want to.
but v3 works great on RB532
Normis can you explain me how I update to superchannel in a 2.9.51 RB…??
Because I select “Work with Key” after that select the key of the RB532 and click on update It tells me “This key already have full features!”… :open_mouth: :frowning:
you have to contact your local MikroTik distributor to obtain this special upgrade
Send mail to support, Still no answer, help please! :open_mouth:
Superchannels work fine with RouterOS 2.9.x. All of my RB532s (about 200) are running 2.9.51 and I have several working with superchannels.
Have you looked at “System > License” in the “Features” window? Does it say anything? It should say “extra-channels” if you have the Custom Frequency upgrade key properly installed. If they are not installed, it will be blank.
Tom
It´s not superchannel installed on the RB, in license features nothing is shown…
I send mails to support and sales and got no answer, the license server must be updated… :open_mouth:
I got an issue using superchannel, ubiquiti customers did not conect on 2.3 GHZ / 20 mhz channel…
It only works on 2.3 / 10 mhz channel.
ROS V 3.30
Seems like here we got a little trouble…
Someone have this issue too???
