SuperChannels compatible cards from 4,870 to 4,940
I have to use this freqs in a project. Wich cards should I use?
thanks,
you can use DBii FN52-Pro card. I schould work with this frequencies.
Sonny
www.citynetz24.de - www.restlesspowerbox.com
Thanks, any other cards?
this is the best card you can get.
But all Compex WLM200NX and WLM200N5-XXXX should work with mikrotik software and superchannel.
try it by your own, with any card you can get.
Sonny
