to test new hardware you do not have to buy the license, you can install RouterOS with demo key that is up for 24 hours. plenty of time to test, if it is working. That is, since you already owned the hardware.
as i wrote before - if you have hardware on your hands you can try either of versions, when you are content with how version works purchase license for the key and apply license. So you avoid all the guesswork and headache
For most purposes L4 is enough. If you want a lot of tunnels you should look at what limitations each license has, also note, that that limit is for active tunnels.
We have tested the D510 in production and it works great with latest Version 5 release. If you are looking for a d510 based router go to balticnetworks.com, they have them available.
We have also used the Atom330 Supermicro board which also works well. If you put that together with HP NC364T, you have a powerful router.
The testing we did was with real traffic around 150Mbps/50Mbps 24k pps
If you are interested in a stable platform that you don’t have to worry about, hit http://www.mikrotkrouter.com. Plenty of options including SFP interfaces as well, and performance testing. Plus you can run v2-v5 on it, so you don’t have to run bata software if you do not wish too.
It does about 1-1.5 gigabit through, although balancing between cores isn’t perfect yet.
If there’s anybody looking for a relatively cheap way to route gigabit, I’d recommend this Supermicro.
But what gives me a headache is - maybe I could have just bought RB1100 and would have fully supported platform.
Hmmm. So next time it would be at least core2duo or simply RB1100.
Not 100% sure but in my tests on the Atom D510 and D525, 4.x didn’t work and 5.x does. I have not tried the latest 4.x but it was not mentioned in the 4.x changelogs and Mikrotik does not usually go out of their way to add new support to the current stable when the beta is close to becoming the new stable.
Here are the pertinent lines from the 5.x changelogs…
What’s new in 5.0rc2 (2010-Oct-27 16:20):
*) added support for more Intel 82575/82576 PCI-Express Gigabit Ethernet cards;
What’s new in 5.0beta1 (2010-Mar-31 09:17):
*) updated drivers and kernel (to linux-2.6.32.5);
*) added support for multiple Intel Ethernet cards;
And 5.x is just about ready for stable so you don’t have too long to wait.
Just to make this 100% certain, after further testing I verified that ROS 4.16 does not support our Atom D510 router hardware using the Intel 82574L/82583V chip sets. ROS 5.0rc9 works great with all the ports.
The CPU works fine with both ROS versions. The Ethernet ports do not work with ROS 4.16.
Thanks Tom for testing this hardware.
I appreciate it a lot.
Anyway - we upgraded one of our BRAS serwers terminating 350 PPPoE sessions by mistake to version ROS 5.0rc7.
It was a disaster. CPU was 100% almost all the time. All interfaces were disappearing and appearing .
So i think we will wait for stable ROS 5 or just buy another NIC.
