I have a network 192.168.0.0/23 set up and have a phone system running on 192.168.1.25. I can ping the phone system from the router, but not from my machine which I am currently VPN’d (PPTP) in on using 192.168.0.48.
Any ideas?
Any ideas?
check if the subnet on the machine is correct
255.255.255.255
I am using a PPTP connection.
I had the sam problem awhile ago where i pptp into network and could not access devices on that subnet.
What i did was to add nat rule.
/ip firewall nat add src address(pptp local address on router) action masquerade.
Hope it helps
No luck. It seems my phone system on 192.168.1.25 can ping a 192.168.0.x address. I really have a hunch it’s the PPTP connection not working right.
Is proxy arp enabled?
Proxy arp is enabled on the bridge-local
Can you ping the router when connected with vpn?
What does your computer show when you try to traceroute to the phone and to the router?
Have you setup /23 network on both sides?
If I am on a 192.168.1.x address, I cannot ping the router, only the phone system, with tracert,
Tracing route to 192.168.1.25 over a maximum of 30 hops
1 22 ms 22 ms 26 ms 192.168.0.1
2 31 ms 22 ms 23 ms 192.168.1.25
