Supplier for 50cm cables RP-SMA-Male <-> MMCX
hi @ all,
i was looking for 50cm RP-SMA-Male ↔ MMCX cables but only found one source in the US which was reasonable in price. does any of you guys know where in europe i could get them or have them made at a reasonable price ? postage from the US is just a joke, otherwise i had no problem with that.
thanks
Jan
50cm is quite long most of the suppliers i just checked have from 18 to 30cm, can i ask what type of antenna are you using as i use much shorter and have no difficulty, on a few occasions had to move routerboard for cable to reach?
ps - greeting from Limerick
I am using a UBNT sector antenna and RB433AH with R52HN in outdoor enclosure. 50cm is the minimum to get it done ok. we have a number of these setups out there and they are the best solution we found so far to minimise coax cable run and mixing UBNT antennas with RB’s. so far i get them from the US but shipping is way to expensive.
Jan
You could try Ebay
http://cgi.ebay.co.uk/RP-SMA-male-MMCX-male-RA-pigtail-semi-rigid-cable-/290384271509?pt=UK_Computing_Networking_SM&hash=item439c405895
They state they will supply custom lengths, worth checking out?
