support mikortik this hardware ?.
I try install 5.20 and don´t found hard drives.
HP proliant DL360 G4.
Regards.
Regards.
Try to install from Serial ATA CD/DVD ROM then will work.
I install from a iso-cd 5.20 and 6.0 but allways not found hard disk . ??? I don’t understand you.
Regards..
You need to set your onboard SATA controller mode to IDE/PATA/Compatibility Mode in BIOS and connect your hard disk to the onboard SATA controller.
RouterOS will not detect most AHCI-SATA controllers, if not all, and will definitely not detect any disks connected to a hardware RAID controller.
My DL360 has not a SATA conector only RAID.
Regards.
onboard SmartArray controller is not support. You can install ROS into USB key instead. it will work.
