We installed a DemarcTech 300mw Prism 2.4Ghz card into a Routerboard the other day to test.
The drop down box for power only goes up to 200mw.
When will this be fixed, and what is the expected behaviour?
it will work at the correct power if you set tx-power=default.
Is there going to be a version that has 300mw or higher in the drop down box?
i don’t know yet, but in any case - it always works better if you set it to default. it then works at the maximum supported
