Are Intel 82573L Gigabit Ethernet controllers supported in
ROS 2.9.x ?
ROS 3.0 beta?
If so, any known issues?
If not - if/when supported?
I couldn’t see them on the 2.9 driver list documentation.
http://www.intel.com/design/network/products/lan/controllers/82573.htm
Regards
bump … anyone?
Would appreciate knowing the answer to this -
Regards
somebody has to test it. v3 has new intel drivers (the latest), so it should work. but I can’t be sure without testing
Thanks very much for the response Normis.
So most likely it will work … and I sense that “someone” might be us …
will post up if/when have time and equipment to hand to do this.
Regards
Normis,
Can you determine the version of the e1000 drivers somehow ? Is it possible to add this into the release notes when the e1000 is updated ?
Sam
In 2.9.43 vlan support is not working with these cards.
v8beta9 works well with them but they refuse to go to gige …100meg max at the moment.
