I have just ordered an Intel Pro/1000 MT Dual Port Server Adapter (Pci/pci-x). According to the supported hardware list on the MT site, it looks like its supported. But after rebooting up with the new card, it doesn’t seem to recognize it. Is there a special driver I have to load? Could it be that it is only supported in PCI-X mode (when I only have a PCI bus)? Or is this card not able to work at all in with RouterOS? If it helps, the system is an older AMD Athlon +1700. And other NIC’s seem to work in the same slot.
Eric
