Support for St. Helens 80G4S-XL // Intel XL710
can someone tell me if the St. Helens 80G4XS-XL or the Network Chipset Intel XL710 is supported by RouterOS, RouterOS is not on the Datasheet.
The Tambora Series with Network Chipset Intel 82599ES is supported and runs fine (L2MTU is not working but it is ok if do not need MPLS), RouterOS is also on the Datasheet.
We run our BRAS-Systems on X86 and want to change one system.
thanks,
glueck
AFAIK you have to wait for ROS v7.
Do you think or do you know that?
regards,
glueck
I think. v7 is rumored to have an updated linux kernel.
