Support solver problem LED RB750 fault
hi all
i have some RB750 problem, LED on LAN is ON when i not connect LAN cable, i user netilstall to reinstall it , but the problem it not solver, anybody can have me? Pls see attach file,
thanks
You can send these to RMA to fix the LED behavior. Or ignore it, if otherwise the operation is fine. It looks like one part is damaged on the PCB
