Supported Browsers
Hi Mikrotik guru’s..
I have a client using a Mikrotik hotspot system with (I have been told) the latest versions running on it. The problem I have is that some users are experiencing problems when purchasing extra download allowance via the paypal feature. Sometimes it works, other times you get timeouts etc.
I firstly want to know if there are certain browsers that this does not work well with?
Are there java issues that I should be aware of?
Any pointers would be appreciated..
Cheers,
Chris
