*** First, let me say the the best multi-port NIC card is the RouterBoard 44. (before you delete this post)
I would like to explain why allowing discussion about other NIC’s would benefit Mikrotik.
I have several small clients that need basic router/firewall appliances. I like to use old PC’s with MikroTik. Its 100% better than off the shelf d-link/netgear routers. BUT the mico PCs that are comming on the market (off lease etc) gives me a wonderfull small platform for a router. You can find them at surpluss for around $25.00 in bulk. However they only have one PCI slot. With an off brand multi-port NIC I can have a SUPER MikroTik router with license for around $100.00
But if I am forced to purchase a Routerboard 44 the system runs well over $200.00 and the d-link/netgear have to be used to save money.
I wan’t to buy Mikrotik licenses! I love the product! we just need a way to cut cost of the NICs -
** long story short - does anyone have 2-4 port NICs that work with Mikrotik? (I listed some before the I can’t seem to find that post) I see alot listed on ebay and similar sites for under $25.00.
