This script will restore resolved domains to static DNS so that IP addresses are know without a server is needed to resolve those right now.
The restored entries in static DNS are renewed not on their original TTL but on the TTL stated in the config line. The config line and the call to run the script in /system/script is placed in /system/schedule with and set it to run on start-up. This script will only restore already resolved domains.
When the script is running then you can see that in the log and any changes are DNS up/down are also logged. To stop the script from running then remove the Global line survive in /system/script/environment and the script will stop and clean all setting made and also the Global line.
The config line and call to run the script used in scheduler as startup:
## version 20220505-001
## Load the configline and start the script
:local scriptName survive
:global survive
#create the global config line and start the script
:global survive { "REMOVE LINE TO STOP SURVIVE-SERVICE";
true; surviveService active;
300; seconds before storing in static DNS will be repeated;
15; minutes before renewing static dns;
[:tostr mt.lv]; canary domain;
true; include canary domain (extra);
true; WireGuard domains;
true; IPSEC domains };
:execute script="survive"; # execute = start and do not wait till scipt has ended
:delay 3s; # check if survive script has started and if it is till running
:if ( [/system/script/job/find script=survive]) do={} else={:set $survive}
:if ( $survive ) do={
# do some logging of the startup of the script and it's settings used
:log info "Survive: service is using the following settings:"
:log info "Survive: service active: $($survive->1)"
:log info "Survive: storing new addresses in static DNS: $($survive->3) seconds"
:log info "Survive: renewing resolved static dns entires (TTL): $($survive->5) minutes"
:log info "Survive: canary domain: $($survive->7)"
:log info "Survive: WireGuard domains added: $($survive->9)"
:log info "Survive: IPSEC domain added: $($survive->11)"
:log info "Survive: NTP-client domain added: $($survive->13)"
} else={ :log info "Survive service is not running. Check if that is correct?"}
The script itself named survive:
# script written by msatter
# version: 20220505-001
# only non-commercial usage of this script
# store domains in address-list and in staticDNS, enabling resolving those when the upsteam DNS is down on restart/crash
# when using manual static DNS entries, put a number in the domain: example.lan.1 to have those are ignored by this script
# remark the TTL in static DNS is irrelevant because DNS cache resolve those, every 10 seconds or so (own observation)
:local surviveActive false; # only start when the config line states true for surviveActive
:global survive; # imports the survive variable containing the config array
:if ( $survive ) do={ # read the survive configline and put the values into the variables
:set $surviveActive ($survive->1) ; # decides if the survive service is active
:set $runEvery ($survive->3) ; # in seconds, storing in static DNS will be repeated
:set $renewStatic ($survive->5) ; # in minutes, renew through erasing static DNS entries (not when DNS resolving is not active)
:set $canaryDomain ($survive->7) ; # canary domain
:set $WGactive ($survive->9) ; # add WireGuard domains to survive
:set $IPSECactive ($survive->11) ; # add IPSEC domains to survive
:set $NTPactive ($survive->13) ; # add NTP domains to survive
}; # EndIf
:if ( $surviveActive ) do={ # do not start survive and remove any earlier stored values staticDNS/address-list/global if they are present
# set to false to indicate that there was start ( tri-state value (true/flase/either) by using on-error )
:if ( [/ip/firewall/address-list/find list=survive address=$canaryDomain] ) do={ :set $displayStart false } else={ :set $displayStart }
# create the canary domain in address list
:do { /ip/firewall/address-list/add list=survive address=$canaryDomain } on-error={}; # will only be active when DNS resolving is available
# calculate the 'TTL' from the number of runEvery and renewStatic
:set $cleanStatic ($renewStatic/($runEvery/60)); # calculate a kind of fixed TTL to be used for survive domains
:if ( $cleanStatic < 60 ) do={ :set $cleanstatic 60 }; # minimal 'TTL' is 60 seconds
# retrieve the lasttime an active survive was done
:do { :foreach i in=[/ip/firewall/address-list/find list=survive !comment] do={:set $lastRun [/ip/firewall/address-list/get $i creation-time ] } } on-error={ :set $lastRun ""}
# logging the startup of
:log info "Survive: for survive domains, has been activated. Updating those every $runEvery seconds";
:log info "Survive: domains are renewed every $renewStatic minutes. Replacing the domains original TTL"
:if ( $lastRun = "" ) do={ :log info "Survive: the domain used, if no resolving is not active, where resolve on: $lastRun" }
while ( $survive ) do={ # start of the loop, only loops if Global $survive is containing values
:local startBench [/system clock get time]; # adding the waiting time for resolving day for added domains
# clean the address-list before refreshing. The canary Domain is not removed because as it not a endpoint domain
:do { [/ip/firewall/address-list/remove [find list=survive address!=$canaryDomain comment!=$canaryDomain]] } on-error={}
# Loop to fill the address-list "survive
### add WireGuard peer addresses if WGactive = true
:if (WGactive) do={ :foreach wg in=[/interface/wireguard/find disabled=no] do={
:local nameWG [/interface/wireguard/get $wg name]
:foreach peerWG in=[/in/wireguard/peers/find interface=$nameWG endpoint-address~"[a-z]\$"] do={
:local endPointDomain [/interface/wireguard/peers/get $peerWG endpoint-address]
:do { /ip/firewall/address-list/add address=$endPointDomain list=survive } on-error={}
:do { /ipv6/firewall/address-list/add address=$endPointDomain list=survive } on-error={}
}; # EndForEach
}; # EndForEach
}; # EndIf
### add IPSEC peer addresses if IPSECactive = true
:if (IPSECactive) do={ :foreach peer in=[/ip/ipsec/peer/find disabled=no address~"[a-z]\$]"] do={
:local peerDomain [/ip/ipsec/peer/get $peer address]
:do { /ip/firewall/address-list/add address=$peerDomain list=survive } on-error={}
:do { /ipv6/firewall/address-list/add address=$peerDomain list=survive } on-error={}
}; # EndForEach
}; # EndIf
### add NTP client
:if (NTPactive) do={ :foreach server in=[/system/ntp/client/servers/find address~"[a-z]\$"] do={
:local serverNTP [/system/ntp/client/servers/get $server address]
:do { /ip/firewall/address-list/add address=$serverNTP list=survive } on-error={}
:do { /ipv6/firewall/address-list/add address=$serverNTP list=survive } on-error={}
}; # EndForEach
}; # EndIf
:delay 5s; # allow the address-list to resolve, the just added domains. time lost, is compensated in the waiting loop
# check if resolving is available. if not then, no adding/removing is done to the static DNS
# this mean that no comment should be entered to the survive address-list to keep this working
# as soon as DNS resolving is restored the dyamic entries in the survive address-list is activated again by RouterOS
:if ( [/ip/firewall/address-list/find list=survive comment~"[a-z]\$"] ) do={ # when domains are found in (Dynamic entries) comments then resolving is available after startup
# Clean static DNS of survive entries ever so many cycles
:if ($cleanCount >= $cleanStatic ) do={ :set $cleanCount 0; :do { /ip/dns/static/remove [find comment=survive] } on-error={ :log warning "Survive: no endpoint domainnames found" } }
# put survive addresslist into an arrayIPv4
:local arrayIP [:toarray ""]
:local arrayIPv4 [:toarray ""]
:local arrayIPv6 [:toarray ""]
:foreach k,v in=[/ip/firewall/address-list/find list=survive address!=$canaryDomain comment!=$canaryDomain] do={
:set (($arrayIPv4->$k)->0) [/ip/firewall/address-list/get $v address]; :set (($arrayIPv4->$k)->1) [/ip/firewall/address-list/get $v comment]}
:foreach k,v in=[/ipv6/firewall/address-list/find list=survive address!=$canaryDomain comment!=$canaryDomain] do={
:set (($arrayIPv6->$k)->0) [/ipv6/firewall/address-list/get $v address]; :set (($arrayIPv6->$k)->1) [/ipv6/firewall/address-list/get $v comment]}
:set $arrayIP ($arrayIPv4,$arrayIPv6)
:set $arrayIPv4; :set $arrayIPv6; # remove IPv4 and IPv6 array's
# Loop, to fill static DNS with resolved
:foreach k,v in=[($arrayIP)] do={
:if ( [:typeof (($arrayIP->$k)->0)] = "str" ) do={ :set $surviveDomain (($arrayIP->$k)->0) }; # EndIf
:foreach ka,va in=[($arrayIP)] do={
:if ( $surviveDomain = (($arrayIP->$ka)->1) ) do={ #surviveComment
:set $surviveIPaddress (($arrayIP->$ka)->0); # EndIf IPv6
:put "$surviveDomain $surviveIPaddress"
}; # EndIf
}; # EndForEach
# double added if there are also IPv6 entries. This causes no extra writes into flash
:if ( [:toip $surviveIPaddres] ) do={ :do { /ip/dns/static/add name=$surviveDomain address=$surviveIPaddress comment=survive type=A; } on-error={} }; # EndIf
:if ( [:toip6 $surviveIPaddres] ) do={ :do { /ip/dns/static/add name=$surviveDomain address=$surviveIPaddress comment=survive type=AAA } on-error={} }; # EndIf
:set $surviveIPaddress; # clears previous IP address to avoid that it is set to a previous read domain
} ; # EndForEach
:set $cleanCount ( $cleanCount + 1 )
# setting cleanCount to cleanStatic, innitiating a rebuild of static DNS survive domains, this whenever resolve DNS is restored after restart/reboot
} else={ :set $cleanCount $cleanStatic }; # EndIf EndElse
# do logging when DNS resolving was not available on start-up
:do { :if ( [/ip/firewall/address-list/find list=survive comment=$canaryDomain and $displayStart] ) do={ :log warning "DNS resolving has been restored."; :set $displayStart } } on-error={}; # log only once when DNS resolving is restored
:do { :if ( [/ip/firewall/address-list/find list=survive comment=$canaryDomain and !$displayStart] ) do={} else={ :log error "DNS resolving not available, check your DNS!"; :set $displayStart true } } on-error={}; # log only once when DNS resolving is not available
# deduct benchTime to emulate a TTL that has been defined in the configline
:set $benchedTime ([/system clock get time]-[:totime $startBench])
:set $correctedRE ( $runEvery-(([:pick $benchedTime 6 8])+([:pick $benchedTime 3 5]*60)) ); # correct dynamicly, runEvery with the needed processing time in seconds
:if ($correctedRE < 0 ) do={ set $correctedRE 0 }; :put $correctedRE; # should not be negative
# loop for a calculated number, to emulate a TTL
:set $countTime 0; # reset before delay loop is started
while ($countTime < $correctedRE) do={
:set $countTime ($countTime + 1); :delay 995ms;
:if ($survive) do={} else={:set $countTime $runEvery}
:do { :if ( [/ip/firewall/address-list/find list=survive comment=$canaryDomain and $displayStart ] ) do={ :set $countTime $runEvery } } on-error={}; # while counting DNS resolving came back
}; # delay routine based on runEvery
}; # EndWhile
}; # IF !surviveActive
# removing entries in static DNS and the address-list survive
:do { /ip/dns/static/remove [find comment~"survive"] } on-error={}; # incuding an present canary domain
:do { /ip/firewall/address-list/remove [find list=survive !dynamic ] } on-error={}
:set $survive; # erase the Global configline
# do some logging
:log warning "Survive service has been halted or did not start, all survive entries are removed (static DNS/address-list/Global storage)"
It is still early version and I tested it as far as I could and if you find any problem or have improvements in the script then please use this tread for this.
