Swich 2011 with ROS 6.41.3
Hi
I recently updated the RB2011ilS board router to the latest version 6.41.3.
But I do not know the best way to set the router settings to be an effective switch.
I want to make the first port (which connects me to the Internet) gives the rest of the ports the highest efficiency and speed I hope you want the settings step by step to accommodate them. Because I suffer from several problems, for example:
1-port number seven and it is on the Sector gives Root Port while the port is supposed to be the first port being carried online.
2 - I did not find in this release window Master Port to set the rest of the ports on the first port.
3. When the second port is closed, all service is broken and the router is disconnected.
I also have a question: Will the first port be used if the default settings say that the second port is the main port and why did it change?
Please reply in detail
Step by step
