Hi All,
I’m using a few Mikrotik routers all is working great.
There are a few things that I’m not sure regarding the switch.
What can I do with switch rules? Copy to CPU or redirect to CPU
Master port it’s a must? I can use the port even when it’s a master port
Is there any way to sniff data from the switch?
Many Thanks
Thank you.
What is the actually usage for copying or redirecting to the CPU?
Thanks again.
There is some traffic that will go only through the switch chip and no CPU of the router. You can change that with these features.
Thank you.
Can you please provide an example of a real usage?
Many thanks
Hammy
June 23, 2015, 5:54pm
6
I too would like to see an example of the “redirect-to-CPU” in use. I was hoping to use the switch chip to pass most data at wirespeed, but then use rules to pull some traffic out, process it and pass it on if the firewall rules permit.
+1 it looks that ACL filtering is done without copying to CPU? Do copy to CPU and then firewall cover the rest of cases?
