Was playing around with a RB2011UIAS. In the “quick”-set menu its possible to change between Router-mode and Bridge-mode.
In router-mode there is loads of features (all of routerOS) in bridge-mode it only seem to load SWos.
How can I switch back? I dont see an option to do it and a reset doesn’t seem todo the trick.
Reload your backup configuration you have done before try any change.
You have made the backup, right?
Not at that moment(brand new so no config was done)
But IT was possible to deselect the ports in swos and then routeros was available
So everything is ok now
RB2011UIAS do not have SwOS…
You talk about WebFig and Winbox?
