Hello.
I’m trying to get my CRS125, configured as an access switch that receives VLANs and have them assigned for different ports, to be able to get IP address by DHCP.
add name=bridge1 protocol-mode=none
#...other ports 4-12
add bridge=bridge1 interface=ether12
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1 vlan-id=10
add tagged-ports=ether1 vlan-id=11
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=10 ports=ether3,ether4
add customer-vid=0 new-customer-vid=11 ports=\
ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12
add ports=ether1,ether3,ether4 vlan-id=10
add ports=ether1,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12 \
vlan-id=11
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
ATM switch works as intended:
- port 1 is connected to trunk port on core switch
- ports 3-4 serves as access ports for VLAN 10 which lacks of DHCP server and all of the precious IPs are set manually
- ports 5-12 are access for VLAN 11 and all connected devices receives network settings via DHCP
- port 2 is not added to bridge, because i have already locked myself out the device and it is just a precautionary measure :3
But for some reason switch can’t get an IP and can’t connect to this switch from any port besides port 2!
When i added VLAN 11 to port 1 (/interface vlan add interface ether1 name vlan11 vlan-id=11) i noticed that my router log was populated with entries:
dhcp offering lease aaa.bbb.ccc.ddd for MAC-of-access-switch without success
I think i missed something crucial.
