I don’t think that’s entirely true. If you look at each slave interface in Winbox, you’ll see there are separate counters under the Overall Stats tab that are kept. Seems like if Winbox can pull these counters, then they exist and should be the counters provided when polling the standard SNMP interface MIBs.
I just reset 'em on a both the master and a slave interface on a 493 and the counters are definitely there, just not available via SNMP apparently.
This is also critical for me— many of our boxes run near wire speed on the interfaces so keeping stats on how close they are to saturation is very important but also impossible with this issue.
Anyone from Mikrotik monitoring this post that could address this?
