Hello dear sirs,
trying hard (and failing hard too) to use switch chip functionality on RB951Ui-2HnD (without logical bridge interface). I need to switch some vlans between ports using switch chip and do inter-vlan routing on other vlans too. I stripped all the mess to one vlan id=100 in the config below. PC connected to ether2 can’t even ping ether1.100 address.
# dec/24/2020 15:50:03 by RouterOS 6.46.8
# software id = H75K-QJ4R
# model = 951Ui-2HnD
# serial number = 4AC704B705E3
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-706472 \
wireless-protocol=802.11
/interface vlan
add interface=ether1 name=ether1.100 vlan-id=100
set 0 vlan-mode=secure
set 1 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure
set 2 vlan-mode=fallback
set 3 vlan-mode=fallback
set 4 vlan-mode=fallback
set 5 vlan-header=add-if-missing vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no name=defconf
add ports=ether1,ether2,switch1-cpu switch=switch1 vlan-id=100
add comment=defconf list=LAN
add address=192.168.88.1/24 comment=defconf network=192.168.88.0
add address=192.168.100.2/24 interface=ether1.100 network=192.168.100.0
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input dst-port=22 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Asia/Novokuznetsk
/system identity
set name=Test-GW
/tool mac-server
/tool mac-server mac-winbox
And I don’t even see host MACs:
[admin@Test-GW] > interface ethernet switch host print
Flags: D - dynamic, I - invalid
# SWITCH MAC-ADDRESS PORTS TIMEOUT DROP MIRROR VLAN-ID
[admin@Test-GW] >
Am I going in the right direction or I have to user bridge functionality with hardware offload on that board?
Thanks in advance for your help.
Regards,
Konstantin
