I am having issues setting identity of RB260GS. I wanted to set:
LOCATION - OFFICE - DEVICEn
However, I get cut out, and SwOS version is added after the name. Is this normal, or a bug? Or maybe a browser thing? Tried to the switch, but it didn’t work.
The identity character limit is rather small for SwOS yeah.
I don’t know what exactly you need such a long and complicated identity for, but you might be able to add some of your information to the SNMP settings instead. The character limit might be a little higher there, and you have two separate fields.
