Hello everybody, i have a connection with ADSL, and can anybody tell me how can i configure Mikrotik Router and switch Internet from ADSL modem to another PC..
With ReSpect AltERnATivi
does anybody have any answer please because i need it very much!
Are you going to be using ethernet or Wireless to connect router to mikrotik and mikrotik to pc, and Be more precise on what you are trying to achieve, that would help us help you. thanks -Jordan
listen my friend, i have ADSL connection, so from MODEM it comes in Pc, but i want that from modem put in Mikrotik, and then from Mikrotik take normaly internet.
ADSL (MODEM) ----------- Mikrotik Router ---------- Pc(ethernet connection)
There is quite a bit more information that we would need to know.
Does your DSL require PPPoE?
Does your DSL issue IPs via DHCP, or is it static?
Does it hand out private or public IPs to your computer if you directly plug it in
Do you want to firewall and NAT your computer? Is the goal just traffic shaping?
The diagram you gave is fine. Shoot some answers to these questions and then we can go from there.
My DsL require PPPoE
My DSL issue IPs via DHCP
i cannot see any Ip (private or public)
and i wannt to firewall and nat my computer
P.S, when i wanna connect to this conenction, i must go “Create New Connection”, and i have User and password, so i cant see any ip address..thats all information
Then on the port that you plug into your DSL, you will need to add a PPPoE Client. This will get you your router connected with a public IP
Then add a private subnet, such as 192.168.1.1/24 on your local Ethernet side
setup a DHCP-SERVEr on that port
then all you have to have is a NAT out your PPPoE Interface. . ![]()
man, this is my first configuration from DSL, so i need to go in Interfacce and add a PPPoe Client, in PPPoE client i have to select the Interface and in Dial Out i see that are User and password, have i to write here the username and password of DSL connection?
then i will add an address xxx.xxx.xx.xx/24 in other interface(that customer will take internet)
the DHCP server i know how to set up
the only thing that i wanna know is how can i NAT PPPoE Interface,like another NAT’s, Ip firewall, Nat add chain=srcnat…
Write me this procedure it is right or no.?
ha gmsmstr do you have any answer because i need it very much..?
does anybody have any answer please, cause i need it verymuch..
THankYOu
just have to add yoru srcnat rule. Thats it.
thank you man very much it workeeed..
i have a little question to DHCP Server..
when i setup DHCP server its DNS Address, but what happen if i dont know the ADSL dns
Enable the DNS lookups on the mikrotik and point the DNS server to your MT in DHCP.
where is DNS lookups and tell me the procedure of pointing DNS server in MT DHCP…
because my friend i have configured it and it worked but when i setup the DHCP server i knew the DNS, but in other connections i dont know the DNS..so tell me all procedure because i need it very much..
RESPECT
its a problem here..i tried to configure this and it works, and about DNS Detect i have download a program and it works to, but can anybody tell me its the same connection like PPPoE in Mikrotik, and ADSL ..
hope that you understand me.
look here is one very useful link:
http://www.mikrotik.com/testdocs/ros/2.9/
read topics you are interested in. and then ask questions then it will be much more easier for us to help you and understand what is exact problem
the problem is, i have switched the internet in Mikrotik, and the webPages works well, but i cannot open the MSN , 7.5 and 8.1. It says Troubleshoot..
its any problem with Mikrotik or what
You need to post your configuration.
[admin@MikroTik] interface pppoe-client> print
0 R name=“Alternativi” max-mtu=1300 max-mru=1300 interface=Public
user=“alternativixx” password=“123456” profile=default service-name=“”
ac-name=“” add-default-route=yes dial-on-demand=no use-peer-dns=yes
allow=pap,chap,mschap1,mschap2
i have addedd an ip address 192.168.0.1/24 in Local Interface, and i have setup a DHCP Server in this Interface.
Everything goes right but only MSN Dont Work
