This here below is my configuration
On ether5 is a second mikrotik RB 951G 2HnD connected and there are vlans on it
Set Identity
/systen identity set name=SW01
Set Ether names
/interface ethernet set 0 name=ether1-public
/interface ethernet set 1 name=ether2-local
/interface ethernet set 2 name=ether3-local
/interface ethernet set 3 name=ether4-local
/interface ethernet set 4 name=ether5-local
Create bridges
/interface bridge add name=BR-LAN
/interface bridge add name=BR-MOBILE
/interface bridge add name=BR-GAST
Create VLANs
/interface vlan add name=VLAN-MOBILE vlan-id=10 interface=ether5-local disabled=no
/interface vlan add name=VLAN-GAST vlan-id=20 interface=ether5-local disabled=no
Add security profiles (WLAN)
/interface wireless security-profile add name=TNW.LOCAL authentication-type=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa2-pre-shared-key=“Encryption-key” mode=dynamic-keys
/interface wireless security-profile add name=GAST authentication-type=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa2-pre-shared-key=“Encryption-key” mode=dynamic-keys
/interface wireless security-profile add name=MOBILE authentication-type=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa2-pre-shared-key=“Encryption-key” mode=dynamic-keys
Add virtual AP’s
/interface wireless add master-interface=wlan1 ssid=TNW.LOCAL security-profile=TNW.LOCAL name=VAP-LAN wmm-support=enabled disabled=no
/interface wireless add master-interface=wlan1 ssid=GAST security-profile=GAST name=VAP-GAST wmm-support=enabled disabled=no
/interface wireless add master-interface=wlan1 ssid=MOBIL security-profile=MOBILE name=VAP-MOBILE wmm-support=enabled disabled=no
Add ports to bridges
/interface bridge port add interface=ether2-local bridge=BR-LAN disabled=no
/interface bridge port add interface=VAP-LAN bridge=BR-LAN disabled=no
/interface bridge port add interface=VAP-GAST bridge=BR-GAST disabled=no
/interface bridge port add interface=VLAN-GAST bridge=BR-GAST disabled=no
/interface bridge port add interface=VAP-MOBILE bridge=BR-MOBILE disabled=no
/interface bridge port add interface=VLAN-MOBILE bridge=BR-MOBILE disabled=no
Add ether ports to switch
/interface ethernet set ether3-local master-port=ether2-local
/interface ethernet set ether4-local master-port=ether2-local
/interface ethernet set ether5-local master-port=ether2-local
Set IP addresses to the Interfaces
/ip address add address=192.168.1.1/24 disabled=no interface=ether1-public
/ip address add address=192.9.201.245/24 disabled=no interface=BR-LAN
/ip address add address=192.9.210.1/24 disabled=no interface=BR-GAST
/ip address add address=192.9.220.1/24 disabled=no interface=BR-MOBILE
Set Route
/ip route add dst-address=0.0.0.0/0 gateway=192.168.1.254 scope=30 target-scope=10 disabled=no distance=1
Set NAT masquerade
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ether1-public
Set DNS
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=64 server=192.9.201.5
Turn on WLAN
/interface wireless enable wlan1
Hide SSID wlan1 (mikrotik)
/interface wireless set wlan1 hide-ssid=yes
Set wireless mode
/interface wireless set mode=ap-bridge wlan1 band=2ghz-b/g/n ht-txchains=0,1 ht-rxchains=0,1 wmm-support=enabled
Set wireless channel
/interface wireless set wlan1 channel-width=20/40mhz-ht-above
Set wirless protocol
/interface wireless set wlan1 wireless-protocol=any
Add NTP server
/system ntp client set primary-ntp=192.9.201.5 mode=unicast enabled=yes
DHCP Server BR-MOBILE
DHCP Pool setup
UIT OMDAT DIT VIA STATIC LEASE MOET GAAN
#/ip pool add name=“DHCP-MOBILE” ranges=192.9.202.2-192.9.220.253
Setup DHCP Server
/ip dhcp-server add name=“DHCP-MOBILE” interface=BR-MOBILE lease-time=1h address-pool=static-only authoritative=after-2sec-delay bootp-support=none disabled=no
Setup DHCP Network
/ip dhcp-server network add address=192.9.220.0/24 gateway=192.9.220.1
Add static addresses
/ip dhcp-server lease add address=192.9.220.2 mac-address=00:00:00:00:00:01 server=DHCP-MOBILE
DHCP Server GAST
DHCP Pool setup
/ip pool add name=“DHCP-POOL-GAST” ranges=192.9.210.2-192.9.210.253
Setup DHCP Server
/ip dhcp-server add name=“DHCP-GAST” interface=BR-GAST lease-time=1h address-pool=“DHCP-POOL-GAST” authoritative=after-2sec-delay bootp-support=static disabled=no
Setup DHCP Network
/ip dhcp-server network add address=192.9.210.0/24 gateway=192.9.210.1
Setup HOTSPOT server with Radius for GUESTS
Setup Hotspot Profile
/ip hotspot profile add name=“GAST-PROFILE” hotspot-address=192.9.210.1 dns-name=“” html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,cookie use-radius=yes radius-accounting=yes
Setup Hotspot Server
/ip hotspot add name=“HOTSPOT-GAST” interface=BR-GAST address-pool=“DHCP-POOL-GAST” profile=“GAST-PROFILE” disabled=no
Setup Radius
/radius add service=hotspot address=127.0.0.1 secret=123456
Add user (Manger voor usermanager)
/ip hotspot user add name=admin password=pwd
Enable Graphs
/tool graphing interface add interface=BR-LAN
/tool graphing interface add interface=BR-GAST
/tool graphing interface add interface=BR-MOBILE
Set Admin password
/user set admin password=pwd
Set Ether speed 1GB/s
/interface ethernet set ether1 speed=1Gbps
/interface ethernet set ether2 speed=1Gbps
/interface ethernet set ether3 speed=1Gbps
/interface ethernet set ether4 speed=1Gbps
/interface ethernet set ether5 speed=1Gbps
End of file
