switch off RB75x LEDs?
I did intsall one RB750G into my bedroom facing towards bed. On the first night I learned what a mistake that was. In the dark, it glow green like damn christmas tree. Did cover leds with black tape, but light is still visible via venting holes. Is there any way to turn off or dimm LED’s on the RB75x series routers?
/system leds print
is empty, and wiki does not say anything nor have any examples about RB750 leds, only about Groove.
Have you tried:
/system leds disable numbers=
since list of leds is empty, I presumed, that numbers can’t be specified.
This seems to be true
[admin@MikroTik] > system leds disable numbers=2
no such item
[admin@MikroTik] > system leds disable numbers=0
no such item
[admin@MikroTik] > system leds disable numbers=1
no such item
numbers: 0
no such item
[admin@MikroTik] > system leds print
Flags: X - disabled, * - default
 #    TYPE                     INTERFACE                  LEDS
[admin@MikroTik] >
maybe those led’s must be added at first somehow (with /system leds add)?
Tried to do that, but disabling it does not turn off any leds, and at the end, added led can’t be removed:
[admin@MikroTik] > system leds add leds=user-led type=interface-status interface=ether2-master-local
 0  * interface-status         ether2-master-local                               user-led
 0 X* interface-status         ether2-master-local                               user-led
[admin@MikroTik] > system leds remove 0
can not remove preset leds
[admin@MikroTik] >
I am experienced the same informative message “can not remove…” on
a RB2011UAS-2HnD-IN as well
Is this a bug from ROS or LEDs can only work in scripting ?
