Switch on RB951G will not work with VLAN id 1
I got the following config:
Trunk with VLAN id’s: 1,2,3,4,10 on ether1; ether5 is planned to be a trunk to another miktorik.
Switch: Atheros 8327
Interfaces master port ether4 on ether1 to 5
Switch port:
ether1: secure, add-if-missing
ether2: secure, always strip, vlan id 1
ether3: secure, always strip, vlan id 1
ether4: secure, always strip, vlan id 1
ether5: secure, add-if-missing
switch1 cpu: secure, add-if-missing
Swith VLAN:
ID 1: switch1 cpu, ether 1, ether 5, ether 2, ether 3, ether 4
ID 2: switch1 cpu, ether 1, ether 5
ID 3: switch1 cpu, ether 1, ether 5
ID 4: switch1 cpu, ether 1, ether 5
ID 10: switch1 cpu, ether 1, ether 5
VLAN interface on ether4
vlan1: id 1
vlan10: id 10 + management IP
vlan2: id 2
DHCP client on interface vlan1 (id 1) doesn’t get any IP or connection, on vlan2 (id 2,3,4) works OK. On all VLANs except 10 there is a DHCP server and it’s working.
Why it doesn’t work on VLAN id 1? I’ve tried so far releases: 6.19, 6.18, 6.17, 6.16
I’ve got another mikrotik 951 plugged in the same switch doing the same configuration but with bridges, and it works fine on all VLAN id’s.
I’ve downgraded to 5.26 and VLAN id 1 works, but the rest don’t as they supposed to.
On the 6.9 to 6.19, VLAN id 1 does not work! All the others work.
Just for a test I’ve change the config to this:
Ether1 - trunk and master interface for all the other ports
Ether2: vlan id 1
Ether3: vlan id 2
Ether4: vlan id 3
I’ve connected a laptop to ether2 - no DHCP IP was received; on ehter3 and 4 the IP was set by DHCP with no problems.
My conclusion is that this must be a bug :confused:
Nobody has any clue about this?
Well, I’m very new with mikrotik but vlan 1 uses to be de default vlan in other brands, and it has some limitations on the way it works.
I’ve recently bought a rb951g and a crs125 for home and I’m also fighting with the vlans on mikrotik. I’have Juniper and Cisco point of view of them.
