Do anybody know if there is any syntax in Switch rule(not ip firewall) to drop everything except specific mak?
I was expected to see something like an exclamation sign in front of mac !XX.XX.XX.XX.XX:XX/FF:FF:FF:FF:FF:FF
Maybe someone more experienced can clarify if it is possible to obtain this.
I am already aware about this alternative but it is not what I need.
I have more ACL rules under it where I have to allow specific traffic.
It looks like this:
Permit only one mac. This means: drop any other mac, I do not want any other traffic.
Allow something more specific next… Since we are here it means we can allow maybe let’s say traffic on port 80
X) - Allow something more specific next…
Last step: Drop all-> Anything that was not cached by allow rules:Drop it
The situation is more complex, but I hope you understand my scenario.
Thank you.
You don’t specify what device of software is being used.
In SwOS you can use port locking and static mac. Port locking disables learning on the port. Static allows you to preload the mac address and it will not age out of the mac table.
Apologies, I forgot to mention, I thought that RouterOS zone is dedicated to it, I am using RouterOS 7.6 with CRS326-24G-2S+
I want to benefit of HW acceleration from SwitchChip, this is why I am using Switch rule.
Well, I already taught about that, there should be no problem in regards to copy/paste but let me tell why it is not feasible.
Number of rules in ACL are limited.
If you add the rules in the manner that I explained initially:
drop all unnecessarily mac from port1
drop all unnecessarily mac from port2
drop all unnecessarily mac from port3
drop all unnecessarily mac from port4
allow traffic for port 443 on all tcp ports
allow traffic for port 443 on all udp ports
allow traffic for port 80 on all tcp ports
allow traffic for port 80 on all udp ports
drop from all ports
I hope you understand that by having this design, rules 9, 10, 11, 12 and many others after are entered once, they are available for all ports.
By hardcoding mac on these lines means I have to duplicate each line for every single port in the switch.
So each * 24 ports..I think you got it why it is not scalable and feasible.
But in the end I think I got it. It seems RWOS is simply not feasible enough to achieve my needs using hardware acceleration.
I will try to look for another solutions on the market.
For the feature, in case R&D will take an eye on forum and maybe see this post, I suggest the following potential enhancement:
Include ! in the following sections:
Why are you trying to do this filtering on the switch, instead of your BSD based firewall?
I really don’t understand what you are trying to do. The ACL on the switch is going to stop after the first match, so I don’t understand how it would get to the third rule.
I think you are trying to use the wrong tool for the job.
When you were talking about mac addresses, I thought you were interested in port security, but then you started talking about L3 and L4 filtering.
Rule 1-> Drop on switch port 1 !6d:48:77:9c:7a:fc
Rule 2-> Drop on switch port 2 !6a:ed:34:dc:d8:cc
Rule 3-> Drop on switch port 3 !3b:10:4d:f7:95:ab
Rule 4-> Allow on tcp ip port 80
Rule 5-> Allow on tcp ip port 443
Rule 6-> Drop all on all switch ports
I hope it is more clear now how it supposed to work and why I asked about exclamation mark.
It does appear that at least the QCA8337N switch chip supports inverse check. Where I saw the info. google search for qca8337 programming manual and look on page 48.
So as long as the switch chips all support this “inverse EN”, I agree with you, it should be possible to match !mac
