I have a RB750G where I connect, say eth3, a pc and on eth4 another pc.
I need that the RB tag the traffic incoming eth3 traffic with a vlan id (a simple access port in cisco dialect), so I create the following rule.
/interface ethernet switch rule
add copy-to-cpu=no disabled=no mirror=no new-dst-ports=ether4 new-vlan-id=98 \
ports=ether3 redirect-to-cpu=no switch=switch1 vlan-header=not-present
But… it doesn’t do its work. The traffic are simple forwarded without tag.
Can be a bug or a misusing feature?
I tried, more or less, all the facets of the rules but seem that the traffic are ever tagged.
In my test the “only” rules that works are:
- forward an already tagged traffic from an ethernet port to another
- modify tag id from an already tagged packet incoming from a port with another tag outgoing to another port
Here I have a factory default RB with only that rule.
If you need other infos, I’m here.
Thanks,
Michele
