i only will allow PPPoE from ports on CRS317 to uplink-port. no access to switch from customer-ports, nothing. only PPPoE…
I have set these rules:
/interface ethernet switch rule
add disabled=yes mac-protocol=pppoe-discovery new-dst-ports=sfp-sfpplus1-uplink ports=sfp-sfpplus2-205162,sfp-sfpplus3-202669,sfp-sfpplus4-202490,sfp-sfpplus5-201434,sfp-sfpplus6-ebert-hs8a,sfp-sfpplus7-200452,sfp-sfpplus8-206799 switch=switch1
add disabled=yes mac-protocol=pppoe new-dst-ports=sfp-sfpplus1-uplink ports=sfp-sfpplus2-205162,sfp-sfpplus3-202669,sfp-sfpplus4-202490,sfp-sfpplus5-201434,sfp-sfpplus6-ebert-hs8a,sfp-sfpplus7-200452,sfp-sfpplus8-206799 switch=switch1
add disabled=yes new-dst-ports=sfp-sfpplus16-blackhole ports=sfp-sfpplus2-205162,sfp-sfpplus3-202669,sfp-sfpplus4-202490,sfp-sfpplus5-201434,sfp-sfpplus6-ebert-hs8a,sfp-sfpplus7-200452,sfp-sfpplus8-206799 switch=switch1
o.k. Work.only PPPoE is allowed. But when i activated, then the Bridge learns no mac from the ports. So the Bridge sends out the incomming traffic to all ports?!
Must i set
copy-to-cpu (no | yes; Default: no)
Is this not CPU overloading?
I may be missing something, but as the switch chip is forwarding the traffic among its ports on its own using its own forwarding table implemented in hardware, there is no need that the bridge was learning the MAC addresses as well. It can only learn them from broadcast frames which do not appear any more once all the PPPoE sessions establish, so the MAC addresses age out from the bridge’s table.
Other than that, you don’t need to sacrify one port (sfp-sfpplus16-blackhole) to create a “drop all” rule - it is enough to set new-dst-ports to an empty string in the last rule.
Assuming that:
the S+1 interface is the PPPoE server side;
the S+2 interface is the PPPoE client side;
that XX:XX:XX:XX:XX:XX is the MAC of the PPPoE server.
If there is no configuration in the “Action” tab, this is an accept rule.
If “Set New Dst. Ports” is checked in the “Action” tab and no port is specified, this is a drop rule.
clearify. You mean, that i must inset the MAC of PPPoE Server and must inset the MAC of PPPoE-User?
No other Way, that the Bridge learn the MAC-Adresses in case of set ‘only PPPoE’ usable from User without “Bridge filter” (that disables Hardware-Offloading) ?
I have install this. But then i loose the connectivity to my switch.
I managed the Switch via VLAN with IP on S+1
The VLAN should be accesible from outside to the switch.
vlan is set on Interface->vlan, it should not be affectet in the switch-rules, but why? same MAC-Adress?
The green rules are Accept rules. The red rules are Drop rules. If you want have management VLAN, you must configure a accept rule to management VLAN before of drop rule:
but now i will add iptv.
iptv streamer an dhcp-server for cpe on vlan10 on uplink-port.
customer should become an ip adress für his cpe and iptv over vlan10 on his interface. igmp-snooping is not need.
is there a way to enable only dhcp and multicast on vlan10 add to the config above?
