Switch to Cellular data
Hello guys
i have one question of possibility…
Mikrotik routerboard 1000 outdoor type have USB port that’s why it possible to use 3G cellular connection so i thought is it possible to use redundancy? If primary port down, switch to 3G connection automatically.
Dashdorj
There is nothing built-in to do this automatically. You must write your own scripts to switch between various connections when 1 or the other goes down.
It`s simple. You can use routing distance value. Add both default routes with different distance. Route with low distance will be work. Additionally you can enable ping-check on routes. Good luck
you dont need scripts for that
I don’t think it is so clear-cut as you don’t need script for that. There are cases when you would need scripts.
But here is a good guide how to configure failover without scripting:
http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting
Also, I don’t think there is a RB 1000 for outdoor, or am I missing something?
maybe he put an rb1000 in an outdoor box and it’s called Mikrotik routerboard 1000 outdoor type :astonished:
Maybe he meant that USB plug is outside of the case. So users can just plug 3G, 4G dongles. Btw, it would be better if ROS supports WiMax dongles.
