switch to use ..?
Hi, i ordered 3 crs112, im disapointed of the bad performance. I know cpu is only 400mhz, but even for switching this device looks like to be bad.
2 x crs112 linled together:
I cant use the embeded speed test because the cpu is runing to 100% quickly. only 39mbps of troughput.
I i plug my laptop to the switch then the switch to the routeur, i can push 100mbps of my isp bandwith but the cpu is turning around 25%.
I need a better switch.
I need the bandwith test server.
what do you suggest to me?
moved to : http://forum.mikrotik.com/t/switch-crs112/109711/1
Try disable the lcd interface, then the cpu should go down, it does on the crs226
