switches for RB5009
Last day I got an idea: 8G-2S+ switches in the case size of the RB5009/L009
For a small office it could be enough in only 1RU, daisy-chained to the router over the SFP+ ports
Maybe with a software extension, they can work as port extender for the main router, configurable from that ROS
I use CRS310 8G connected with fiber SFP+@10G in small remote sites, and for biggers, i use CRS326.
maybe you want to share your thoughts on that matter on this existent topic
http://forum.mikrotik.com/t/switch-in-rb509-l009-formfactor/180421/1
Benchmark is impossible and complicated
In this case, RB5009 act as routing with lot of differents operators/ISP and speeds.
The 10G connection between RB/CRS is just here to avoid losing eth@1gig and because i had a lot of 10GB sfp.
All theses remotes sites are connected with a WG site2site between two mains sites with big WG servers and internet bandwith… and all remotes collected traffic “start from here”.
Thanks! I tried to search for any similar topic, but I didn’t found, sorry!
